Hi - new to the forum here. I found some older threads on this subject but nothing recent.
Just had our 2020 XC90 Momentum T6 with Polestar, less than 30K miles, towed to dealer after a harrowing on highway loss of power and turtle light coming on dash. Car stumbled, lost power and went into limp mode, barely running. Limped it to a safe spot and had to nurse the throttle to keep it running (driving and at idle)
Dealer has been awesome so far but hasn't got to the bottom of the issue yet (has had only a couple of days). They said the computer kicked out a compression code (or lack of) on cylinders 2,3. Those 2 plugs were super wet from fuel. After new plugs and computer reset, they are still picking up a misfire, but it's running.
There are alot of references to this issue on earlier models in the forum.
My question is whether or not you all have seen this problem on later models like mine?
Looks like the fix ranges from kinda easy, to nightmare on Elm Street.
I have not had excessive oil consumption and the plugs (while wet) were not damaged.
Any fresh/new info on this (or link to newer thread) would be helpful as we diagnose and get it back up and running.
